EE/EF/DA Interchangable parts (Please Add)
167891012»
  • MrJayDMMrJayDM Wagonist
    Buster_gt wrote: »
    anybody know if sedan window guts will fit in a wagon door? i.e. regulator and crank
    YES they just wont roll down all the way.. maybe 1/2" or less of window
  • Buster_gt wrote: »
    They are close. You'd have to swap the part of the regulator that holds the window at the bottom (the beam with 2 bolt holes).
  • Anyone know if a Integra DA front lip will fit the wagon?
  • Need to know what other hood i can use for my 1990 honda wagon
  • El LeonEl Leon Band Wagon
    will the center dash vent part (with the clock) fit from other cars or were they wagon specific? sorry if thats been answered here
    i believe not. i tried it fitting one from a 4door but its more angled bit more than the wagons.
    Is there a definitive answer on SIDE vents for the hatch and wagon interchangeability?
    My passenger side vent just broke and CRX vents are easy to come by.
  • OddMarzOddMarz New Wagonist
    Would a DA or eg/dc front sway bar fit an Rt4wd
    DA would. First page has that info. Not sure about EG/DC.
  • unc25unc25 New Wagonist
    Windshield ...wagon specific or interchangeable with sedan ?!!!???!!??!
  • 91 wagon here need trunk latch, can i grab from hatch or sedan 91? Thanks.
  • @unc25 windshield is not interchangeable.
    @Melma30 are you looking for the striker (bottom) or the latch (top)
    Bottom wagon: 74813-SH5-003
    Bottom hatch: 83305-SD2-003
    Sedan: 74862-SE3-003
    Top wagon: 74800-SH5-013
    Hatch: 74800-SH3-013
    Sedan: 74850-SM4-003
    So the tops -might- work based on part numbers, but it's hard to tell from the IPB drawings. The bottoms are all different.
