88-91 All the Wiring Information You Could Need is in Here.
was searching for some info on plug wire colors to find out what was messed up on my harness and found this little list already made up figured id repost it
88-91 sensor wire colors:
EACV (IACV) - 2-wire connector (if car was DPFI, the connector is green) - one Blue with Yellow stripe and one Black with Yellow stripe
IAT - 2-wire connector - one Red with Yellow stripe and one Green with White stripe
Tandem Control Valve (on DPFI only) - 2-wire connector - one Solid Orange and one Black with Yellow stripe
TPS - 3-wire connector - one Yellow with White stripe, one Green with White stripe and one Red with Blue stripe
MAP - 3-wire connector - one Yellow with Red stripe, one Green with White stripe and one Solid White
FICV (Fast Idle Control Valve on 89-91 D16A6 only) - 2-wire connector - one Black with Yellow stripe and one Solid Blue
Cooling Fan Switch - 2-wire connector - one Yellow with Green stripe and one Solid Black
TW Sensor (Coolant Temp for ECU) - 2-wire connector - one Red with White stripe and one Green with White stripe
Temp Gauge Sending Unit - 1-wire connector - Yellow with Green stripe
Oil Pressure Sending Unit - - 1-wire connector - Yellow with Red stripe
-Distributor Pinouts ( obd1 - 2 included )
1.jpg?t=1267482570
JDM ZC Dizzy
ECU PINOUTS
These are the wire colors on the stock harness (most of them are the same for the non-Si models.
And these are the functions of the wires on the stock harness
DPFI TO MPFI from rywire
From 12volt
1988-91 Honda Civic Stereo Wiring
Constant 12V+
Blue/White
Switched 12V+
Yellow/Red
Ground
Black
Illumination
Red/Black
Dimmer
n/a
Antenna
Driver's Pillar
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/Green
Left Front (-)
Gray/Black
Right Front (+)
Red/Green
Right Front (-)
Brown/Black
Rear Speakers
6 1/2" Rear Deck
Left Rear (+)
Blue/Yellow
Left Rear (-)
Gray/White
Right Rear (+)
Red/Yellow
Right Rear (-)
Brown/White
also from 12volt
1988-91 Honda Civic Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+
White
Ignition Switch Harness
Starter
Black/White
Ignition
Black/Yellow
Accessory
Blue/White
Tach
Blue
Distributor
Brake Switch
Green/White
Brake Switch
Trunk Pin
Green/Black (-)
Harness from Dash INDICATOR
Parking Lights
Red/Black
Fuse Panel
Head Lamp
Red/Blue
Fuse Panel
Hood Pin
n/a
Factory Disarm
n/a
Door Trigger
Green/Red (-)
Driver's Kick
Door Lock
Green/White (-)
In Driver's Door at Door Lock Module
Door Unlock
Green/Red (-)
Horn Wire
Blue/Red (-)
Steering Column, use Relay
This info will be good for those of us who need to know the proper wires for making kill switches or remote starts / locks ect.
Heres a Link to a Thread discussing foglight wiring options
http://honda-tech.com/honda-crx-ef-civic-1988-1991-3/need-fog-light-diagram-2676448/
and
http://honda-tech.com/acura-integra-6/foglight-wiring-harness-solution-2657396/
and
maybe we can make it a thread where we post all the wiring colors or diagrams for future reference instances
thats about all i could think of that would come up
My gift to you fellow wagoneers have a happy new year folks
  • Nice stuff there.
  • klumklum Senior Wagonist
    gracias ill add more as i find more figure its just nice for future ref. to have it all in one place!
  • t9wagont9wagon New Wagonist
    This is an old thread but really no sticky?! Bump for good info
  • MrJayDMMrJayDM Wagonist
    Yes great thread!!
    I'm still looking for a wiring diagram for the auto seat belts..
    All the repair manuals have nothing!!
    No luck on the 90-93 integra manuals ether??
  • This diagram?
    Awesome thank you Sir!!
    Where is the automatic shoulder seat belt control unit located?
    Thanks
  • Is the IAT you show as having red/white and green/white wires the same thing as a coolant temperature sensor and if so, what does IAT stand for? Also, I have a ;91 5-door hatchback. Am I on the wrong forum?
  • no they are 2 different sensors. the iat is the intake air temperature sensor, or sometimes called the air charge temperature sensor. it is in the intake manifold, the coolant temp sensor is in the side of the head.
  • 5 door hatchback? i think you are on the right forum buddy!!! we call them wagons round these parts ^.^
  • Anyone know how to wire in the shift lockup solenoid in auto 88 wagovan? I have a manual harness and that solenoid is only thing keeping me from driving it
  • Yo Does anyone have easy link to how i wire up reverse lights? And fix parking break so i can take key out? Its Auto to manual swap on 91 dx
  • This is all great stuff...but...I have a 91RT4WD. The positive battery cable has had the lug cut off. I have the red cover that holds the 2 20amp fuses that operate the slider seat belts, but no lug to connect to the battery post. And cannot find one with the proper orientation to allow the red cover with fuses to be installed. HOW CAN I WIRE THIS UP? I have read that if I do not wire up the seat belt wires that the car will not start. I would sooner replace the entire cable with new IF ONLY I knew how to do it. Not real good with electronics and wiring schematics so pictures or clear verbiage would be of great value.
