'90 Civic 1.6Ti16: RT4WD Conversion...
90' Civic 1.6i16
D16A9/130ch
Barcelona Green G66-P
No Sunroof
Style :
J's Racing Style Frontlip
OEM Wind Deflectors (I lost one side on the road... :( )
OEM Mudflaps
Chassis :
Rebuilt Steering Rack
OMP Front Upper Strutbar
No-name Rear Lower and Upper Strutbar
Rear Swaybar 15mm
H&R coilovers
EE9 Brake Conversion 260mm
EK4 Caliper Brackets
DS3000 Brake Pads
Energy Suspension Master Kit
New OEM Trailing Arm Bushings
Customized Radius Arms
Toyo R1R
Cockpit :
RECARO leather/alcantara Seats
DC2 Rear Seat
Deep Dish Steering Wheel: 60mm
Mugen Style Shift Knob
EE9 Cluster
Engine :
Mugen / Piv EVO2 in External ROM
VW Golf 2 GTI radiator
NGK Spark Plug Wires
Heatshield Intake Manifold Gasket
Complete 2.5inch Exhaust
Exedy Flywheel 5Kg
P7 Gearbox
New Engine Mounts
Moutain Bike Engine Damper
Password:JDM Battery Relocator
Snap-On Battery Connectors
Port and Polish Head
Wiretuck bay
Complete Homemade Turbo kit T28 from Nissan S14
Small video before turbo kit:
http://www.youtube.com/watch?v=13xvGAZVWNQ
Photos :
www.civicwagon.com
And some pictures of the Turbo kit:
And an estimation of the power at 5psi by an Android application (which works very very well!!!)
RT4WD coming soon...
  • RiB'$RiB'$ Band Wagon
    The sad part of the build...
    :hopelessness:
    And now we are swapping the rear floor pan:
    Now rear suspension has to be 5cm more in the rear and 2cm lower
    So we are modify the rear wheel arch:
    Now we will finish the other side, the back is already finish, and after we have to modify the tunnel!!
  • Holy shit!!!!!!!
    most def in for more!
    Holy shit!!!!!!!
    ditto.
    very impressive.
    so your floorpan swapping the rt into the ef9?
    Yes, it is an ED7 with the rear floor pan of the EE4.
    There are others ways to do the conversion, maybe easier, but my purpose is to have something discrete, something like Honda could do.
    Next week I'll be on holidays so I hope it will move faster... I will keep you informed! Thanks for your comments ;)
    Now THAT is awesome.. This would be fun...
    Yes really, when we cut the floor pan of the Civic with a friend, we look each other, and say "Woh, now we are crazy!!" And we laughed for 5minutes! ;)
    Some pictures of yesterday:
    rear right
    rear left
    rear right
    rear left
    Just to see the difference:
    At the beginning, I wasn't thinking that we will need to swap the tunnel so we have cut it too short at the rear end... So we will have to adapt a little... Nothing compare to the rest lol
    I will have to modify the fixation of my seat too, on the tunnel side they are higher than on the Civic...
    Cut, cut and cut!!
    The car is back on his jack points, welds seems to be stronger enough ^^
    This is really awesome!
    Want to come off with that shuttle roof rack?
    Nice work, and very ambitious. I like it!
    Welding is finish, sealing too, now we have to protect the underbody. And maybe next week end put the 4wd gearbox !! :D
    Undercoat is done, fuel tank, handbrake cable, rear suspension, differential and propeller shaft are mounted.
    Some pictures:
    Next step is fuel lines, brake lines, seats etc...
    Again holy shit.
    Your making it look easy.
  • digdug18digdug18 Band Wagon
    Interesting build. I can only imagine the heat soak in the radiator with the turbo that close.
    Thanks for comments ;)
    For the moment, I have never try the car in summer so I never met any problem. Now I have a jacket on the turbine and with the next step, I will delete the Tbar to take away the radiator.
    We have mounted the rear drivetrain, fuel lines, now we are modify the fuel tubing from the fuel trap, we have also made the hole for the tranny cables... Sorry I don't have any pictures and tomorrow I will leave for 2weeks in Portugal...
    After that I will have few days to continue :encouragement:
    I am very very lucky because my friend continue to work on it!!
    We had to modify the half shaft (we forgot to keep the RT one...) I will change it later...
    And the exhaust:
    We will finish the car maybe next week, but I don't have brackets for the rear disc conversion... Maybe I will wait for the Lowflyin' brackets or if it is too long we will have to fabricate them...
  • Nice fab work on that half shaft...always wondered if that would be possible
    The car is nearly complete!! Only need rear brake brackets.
    Tomorrow we bring it at home
    She is at home!
    I need to change differential mounts, it shakes a lot and hits the rear subframe apart this all goes well, for the moment...;)
    Small video (don't care about the noise, it was the handbrake cable which was touching the wheel)
    http://www.youtube.com/v/snZxEHSM2TI
    Some others pictures:
    Tomorrow I will try to design some brackets to hold rear calipers and contact some machinist this week...
    Somebody is not effing around! Awesome project!
    This is too cool, its been a while since I checked in on this thread- and it looks like she is already done!!! So RAD!!! love the RT sun visors!!
  • Somebody is not effing around!!
    I see what you did there ;)
    Thank you guys!
    First drawing of the calipers brackets is sent to the machinist for quotation and feedback.
    It needs some minors modifications but for quotation should be enough.
    Cool Build!!!
    Interior after some cuts:
    holy crap this is going to look totally factory by the time you are done.
    only thing that looks out of place right now is the brake line.
    Brakes are done and I ride the car 2h this afternoon , on dry condition and then wet condition, even in first gear I am able to be full throttle without any traction loss!! I am very happy!!
    Need some work to be perfect, fuel level sensor doesn't work, some boost cut or something like this, need to install rear diff bushing mod from VIPWryann... I hope i will be able to do a track day in few months!!
    To bend the hand brake bracket :lol:
