Chaife's 91 CRX Si resto.
245
    Also started piecing together the trim. After hitting it all with some elbow grease and some love. AKA trim black. lol
    And getting the bay ready for the motor.
    Re-wrapping the harness
    paint booster
    paint cross-member
    paint core-support
    That is totally what I want to do to my crx as well.
    mad props.
    I've been starting to collect parts for my crx as well.
    WOW! This CRX is coming out beautiful! Keep up the good work.
    Fire mat restored and mounted (terrible picture)
    New M/C and battery tray
    Now we're ready for some mota!
    Finished re-wrap on the engine harness
    rear bumper support finished and added
    Window trim finished
    Rear interior section cleaned up and mounted
    And decided on a factory look for the VC
    Had some big boy parts come in last week.
    a set of Yellow Speed's coilovers (very very impressed.)
    Billet fender washers
    Billet battery tie down
    and aluminum lug nuts
    and of course, some wheels...
    what? what could those be?
    BLING BLING!
    15x8 +25
  • P WizzP Wizz New Wagonist
    Awwww heeeeeell yes/
  • danzdanz Wagonist
    i hope they look better on your CRX than they do on the wagons. they look like shit on wagons for some reason...
    its weird because the 92 is one of my fav wheels
  • 666DAN666DAN Wagonist
    X2
    Wicked!!
    NEARLY FINISHED!
    I wonder what the record is for fastest build/ restoration....? lol J/K
    Yellow Speed installed
    Motor in!
    headlights, fenders, bumper support
    rear bumper skin and taillight sections installed w/ junkyard triangle trim
    absolutely amazing work!
    want to do my wagon next? =D
    looken dayummmm good...
    like those fender washers, passwordJDM???
    Its something I sell... Got them on my wagon now too.
    Wheels and tires mounted...
    205/50/15 Nitto NEO GEN
    And a quick fit check, they don't really work yet.
    Too low, needs alignment, needs preload adjustment, needs camber adjustment,
    also need to bat-roll the fenders. :oops:
    vvv wheel mounted w/ car on jack stands... vvv
    Man this is looking so nice, makes me want to give my crx some lovin...
    Those fender bolts and washers are sexy as a mofo too!
    But
    The wheels are friggin awesome!
    rims are $$$$$$$$!
  • danzdanz Wagonist
    with those 205's its gonna be a squeeze but its gonna look great if u can pull it off!!
    welded in some harness tabs/mounts, seats in, new belts.
    with no cutting done to interior. :roll:
  • ColeCole Wagonist
    I hate to be a debbie downer but that is a horrible way to mount your harness. I see it all the time and it makes me cringe. The harness should be mounted on a harness bar or roll cage so the belts are flat with the top of the seat and shoulder area. If there is too aggressive of an angle from the mounting point to your shoulders and you were to get in an accident it can compress and crush your spine. If you don't have a harness bar, roll bar, or roll cage in your car, you really should not install a racing harness in your car, because there is really no other way to do it safely.
    Yes sir, Thank you. What Cole is saying is very true. I should have probably mentioned that in my post.
    This thread is not a good example for installation as far as seat belt harness' are concerned.
    DO NOT run your belts in this fashion!!! (DO NOT try this at home) lol
    I felt comfortable installing the belts like this knowing it will never be my DailyDriver or my racecar...
    And it will never be getting a large amount of use.
    Quarter windows in.
    Some cool shots over the course of the build.
    Car is finished! I drove it... Everything works, and it is really nothing short of a dream. :mrgreen:
    JVC headunit installed
    Rear speakers installed
    Ride height set
    Toe set
    Camber set
    New steering wheel
    Antenna delete
    No clicking
    No rubbing
    No rattles
    No bouncing
    No vibrations
    No squeaks
    No clunking
    No scraping
    Straight butter son! w/ a quiet cabin space?? WTF, is this even an EF?! hahaha
    "And I'll be smiling all the way to the bank" - "Seacrest, out!"
  • DAMN just read this and all i can say is DAMN. :shock: Good job man the car is immaculate!!
    Engine bay, not finalized yet, but complete.
    Thank you sir.
    Chaife wrote:
    No clicking
    No rubbing
    No rattles
    No bouncing
    No vibrations
    No squeaks
    No clunking
    No scraping
    awesome!!! fastest build ever...
    Finally got a few seconds to mention the motor's specs.
    Its a stock/ rebuilt D16A6; w/ ALL NEW HONDA Genuine parts.
    HONDA Water pump
    HONDA Oil pump
    HONDA Oversize D16A6 pistons
    HONDA rings
    HONDA bearings
    HONDA Wrist pins
    Mods:
    P28 ECU no rev limiter
    ARP Head bolts
    3 angle valve job
    Goodyear timing belt
    ISKY Titanium Retainers
    ISKY Valve springs
    DC Sports Header
    EBAY Intake
    VMS Spark plug wires
    PurePower Oil Filter
    MagnaFlow Muffler
    MagnaFlow High Flow Cat
    She put down like 111HP to the wheels in my old CRX.
    on OEM B16 exhaust mani.
    Stock Exhaust
    Stock Air box
    w/ LS B18 intake tube
    I wonder where that number is at now?!!?
  • Jesus, I wish I had the skills and not to mention the funds to restore my wagon like that. Great job sir. crx is looking amazing.
    Hey what did you use to make the window trim and moldings look brand new again?
